Hey guys, I'm in search of a light, padded carry bag that i can fit in my Denon mc4000 and a laptop perfectly . Can anyone recommend me of any pls ? Thanks
geposted Wed 06 Jul 16 @ 12:38 pm
Laptops can go from 13" to 17" so what do you have?
There are custom bags for the controller itself however getting something to fit both perfectly (with cables etc.) will be trial and error.
geposted Wed 06 Jul 16 @ 12:41 pm
My laptop is small, 13. The main thing is for my controller to fit in. Basically I'm looking for a 20inches wide bag.
geposted Wed 06 Jul 16 @ 12:46 pm
I'm not sure if this bag is the perfect choice for your MC4000, but have a look at the other UDG bags.
I'm using one for my SX and it is just perfect. Everything fits in. Laptop, Controller, audio and video cables, hdmi splitter, microfone, usb hub...
https://www.udggear.com/udg-ultimate-producerbag-large-black-orange-inside
Sorted "by device"
https://www.udggear.com/by-device/denon/mc4000
Sorted "by device"
geposted Wed 06 Jul 16 @ 2:25 pm
Heres what I use with my MC4000, http://www.odysseygear.com/odyssey-products/brldigitalxl.html
This bag is perfect!!
geposted Wed 06 Jul 16 @ 3:27 pm
I like the odyssey bag but they are quite dear. Any other suggestions pls ?
geposted Mon 18 Jul 16 @ 10:42 am
A good bag is worth every penny.
Don't go and buy some cheap stuff. You will end up paying twice.
geposted Mon 18 Jul 16 @ 12:55 pm
Co-sign this ^
Just save up the money and do I right the first time.
geposted Mon 18 Jul 16 @ 1:53 pm
Agreed. Cheap bags fall apart in no time. The Odyssey gear is top notch and worth every penny.
geposted Mon 18 Jul 16 @ 1:56 pm
Im seeing the odyssey bag for £99+ Too expensive I'll say.
I think it's ridiculous the amount of money they charging for a controller bag that cost almost half price as a controller! It's so no fair but I got no choice if you guys say its worth it then I just have to save and buy one
geposted Tue 19 Jul 16 @ 12:26 pm
Consider this - what's the total value of your controller and your laptop? You say you want the bag for both. Aren't they worth protecting?
geposted Tue 19 Jul 16 @ 6:24 pm
