I am currently using Fade (remove intro/outro) & 0 seconds. I have set a lot of cue point manually and VDJ has saved those settings. My question is, it I experiment by changing 0 seconds to 1 or 2 seconds or change the type to Fade (remove silence) will the cue points I changed and saved come back if I revert back to Fade (remove intro/outro) & 0 seconds? I have saved the database on a thumb drive so I guess I could always get the cue points back from that but I want to make sure before I start to experiment and possibly lose all the cue points I changed!
geposted Fri 08 Jul 16 @ 6:44 pm
They don't have anything to do with each other, you will be fine.
geposted Sun 10 Jul 16 @ 12:42 am
Thanks...
geposted Sun 10 Jul 16 @ 1:51 am
