I updated to version this week. The first night using it was trouble free. Tonight however, i am getting constant screen freezes where I can not search or use any of the on screen functions. The sound continues to play and i can start the next song using using the controller. Any ideas?
geposted Fri 15 Jul 16 @ 3:09 pm
ugabuga wrote :
Going to start a new thread on this. A definite pattern happening. Every song is causing a screen freeze when it hits 50 seconds. Looks there is a problem writing the song title to the playlist. Everything is locked on the computer screen for about 1 min, then it comes good.
Took this info from a related post he started 2 hours after this post, which I closed.
What is your OS, and video card? Do you have the same issues if you revert back to previous version?
geposted Sat 16 Jul 16 @ 7:01 am
This is a thing gor me too..
If i see the load security too much eventually i cant click on anything in the skin..
When load security or even right click menus, he skin dimms during pop ups.
geposted Sat 16 Jul 16 @ 10:56 pm
Check this thread:
https://virtualdj.com/forums/211052/VirtualDJ_8_2_Technical_Support/8_2_b3311_new_videoForceFullscreen_1_issue_-_other_issues_seem_ok_now.html
using videoForceFullscreen=1 can lock up the user interface in some cases. use videoForceFullscreen=0 until they fix it.... report back if this was your issue or not.
geposted Sat 16 Jul 16 @ 11:04 pm
My virtual dj 8 screen froze but music kept playing as well with latest build. Nothing would work. Had to restart the computer. Any ideas? Using a mac with el capitan and hercules dj4 console.
geposted Sun 09 Oct 16 @ 1:06 am
