I used to be able to connect wirelessly to the Internet, on my Windows based laptop, to verify my monthly subscription to Virtual DJ. Just recently something happened to my wireless connection, and the laptop will no longer connect to the Internet. What other method can I use to verify my license? I have a gig coming up on the 30th, and I need to know what to do. My home computer is an Apple, so I can't afford to run two versions of Virtual DJ - one for each operating system.
geposted Sat 16 Jul 16 @ 6:32 pm
Hardwire your Windows machine to the router [rj45 cable] [once a month], I really can't see another solution, unless atomix has some sort of app that you can extract and sent your offline machines hardware profile to them [via removable storage to an online machine] and they can send you a perishable licence.dat [unlikely]
geposted Sat 16 Jul 16 @ 6:54 pm
An Offline license can be provided only for Pro Infinity. The Pro Subscription requires online verification.
Purchasing Pro Infinity provides you both Windows and Mac License of course.
Please contact support for further details
geposted Sat 16 Jul 16 @ 7:24 pm
A license is a license. It doesn't matter which version of VDJ you run.
My Pro license gives me access to both PC and Mac software, so I'd assume that a Pro subscription does the same.
Mind you, logging in on your Mac isn't going to re-validate the PC laptop. Each machine requires a different license.dat so you do need to connect the laptop.
As locodog says, connect using a cable or get yourself a wifi dongle.
geposted Sat 16 Jul 16 @ 9:11 pm
