Can some one help me mapp a button to select video fx on main screen. Anything i did selected deck 1 or 2.
Thank you Tomas.
Thank you Tomas.
geposted Tue 19 Jul 16 @ 8:25 pm
deck master video_fx_select (select - usually for knobs/encoders - if mapped to a button, it offers the drop-down list)
deck master video_fx_select -1 (select previous)
deck master video_fx_select +1 (select next)
deck master video_fx (turn on/off)
geposted Tue 19 Jul 16 @ 8:29 pm
Thank you djdad. Worked fine. deck master was the problem.
Thanks again. Best regards Tomas.
geposted Tue 19 Jul 16 @ 8:40 pm
