I recently updated to the latest virtual dj 8 and it changed the skin. Two of the custom buttons have disappeared, along with all the code that I painstakingly attached to them. I have a gig in 2 hours. I have not time to rewrite the interface. How do I get back to the previous default skin?
geposted Thu 21 Jul 16 @ 11:08 pm
On the 8.2 skin, custom button are hidden by default. You can unhide them by going to the layout dropdown at the top of the skin (where you select the number of decks). A more detailed explanation can be found here: https://virtualdj.com/manuals/virtualdj8/interface/decks/decksadvanced/custombuttons.html
geposted Fri 22 Jul 16 @ 12:54 am
Just a word or two of advice...
NEVER update anything about your dj software or files prior to a gig. Save those things for when you have a good amount of time before your next job. That way, you can troubleshoot and fix any problems that may come up. Gives you a chance to run things through their paces.
Good luck with your gig tonight. Rock it out.
geposted Fri 22 Jul 16 @ 4:06 am
what he's saying is, there use to be 4 buttons on each deck and now theres 3 on each deck. AceMan, iv tried what you wrote and the 4th buttons on each deck didn't appear... on my mac
geposted Fri 22 Jul 16 @ 10:06 am
Yes, the new Default skin of Version 8.2 has one Custom button less, due to less available space around jogs (some space is reserved for TC, AUX and Key Panels too in case you ask). However, you have now a Custom Pad page with 8 more (+8 with SHIFT or right-click) custom buttons per deck to use, along with more Custom pads pages that you can create, so the possibilities are endless.
If for any reason you need to use the skin of ver 8.1, you can download it from here.. https://virtualdj.com/documents/Skins/VirtualDJ%208.zip but you will lose the new Pads and Browser Zoom functionality.
Or of course use any other Custom skin that may offer 4 or more Custom buttons.
As for the "lost" scripts, if you open Settings->OPTIONS tab and search for the setting CustomButtons, you will find your scripts in the field, and you can copy-paste them to either a Pad of the Custom page (using the Pad Editor) or to an existing Custom button as a secondary action.
geposted Fri 22 Jul 16 @ 1:09 pm
Thanks for all the helpful answers guys :) I had to drop the integrated lights which I usually run through VDJ and freestyler, but the crowd didn't notice as it was the first time I've played at that venue. The night was a success... And yep, never update before a gig, lesson learnt!!!
geposted Fri 22 Jul 16 @ 1:39 pm
is this the one from DJ touchdan, DAD?
geposted Sat 23 Jul 16 @ 1:39 pm
