I am currently running VDJ 8.2 Pro on a Windows 10 laptop. I am wondering if it is possible to go back to Version 7?
geposted Fri 22 Jul 16 @ 3:51 am
VDJ 7 or Windows 7?
geposted Fri 22 Jul 16 @ 4:09 am
Subscribers can only use VDJ 8, because VDJ 7 has no online licensing technology built in.
Of course you could always BUY a full Pro Infinity licence, which includes VDJ 7 Pro.
geposted Fri 22 Jul 16 @ 8:33 am
Keep in mind also, I dont think the V8 database is backwards compatible with V7. So all your cue points, loops, and other data that you have in your V8 database wont transfer to V7. Maybe someone else can confirm that, but I thought I read that was the case. You can only transfer your V7 stuff over to V8.
geposted Fri 22 Jul 16 @ 2:58 pm
Not correct ;)
You can try this tool:
https://virtualdj.com/plugins/?addonid=80185
geposted Fri 22 Jul 16 @ 3:10 pm
I should edit it to say that it's not backwards compatible right out of the gate. Need a separate plugin for it. :)
geposted Fri 22 Jul 16 @ 6:20 pm
