hi,
i have a 6 sec video i want to use in 1 deck to loop with..but i dont want to create Sample loop since that doesnt behave with other decks like a video would if it was on a deck.
is there a simple way to set the deck 1 to loop at END?
thanks!!
thanks!!
geposted Fri 29 Jul 16 @ 8:11 pm
this is what I use (works for me)
set a CUE on the beginning (let say cue 3).
at the end, use POI to loop back using ACTION goto_cue 3.
geposted Fri 29 Jul 16 @ 9:25 pm
No need to mess with Poi Editor and CUES.
Simply assign a custom button (or a button on your controller) as ..
repeat_song
Whenever you want the track to start over when reaching the end (loop whole track), simply enable the custom button.
repeat_song
geposted Fri 29 Jul 16 @ 9:41 pm
