Hello
I need your help for programming Novation Launch Control please !
I do not speak English I use a Google Translate sorry !
I can not operate the LED Novation Launch Control
I wish that when the effect is activated ON the LED turns red
Thank you Dj Fil
http://d19ulaff0trnck.cloudfront.net/sites/default/files/novation/downloads/6958/launch-control-programmers-reference-guide.pdf
<map value="0-BUTTON9" action="var '$fxtrans' ? video_transition : deck left effect_active 1" />
<map value="0-BUTTON10" action="var '$fxtrans' ? video_transition : deck left effect_active 2 " />
<map value="0-BUTTON11" action="var '$fxtrans' ? video_transition : deck left effect_active 3" />
<map value="0-BUTTON26" action="var '$fxtrans' ? video_transition : deck right effect_active 1" />
<map value="0-BUTTON27" action="var '$fxtrans' ? video_transition : deck right effect_active 2" />
<map value="0-BUTTON28" action="var '$fxtrans' ? video_transition : deck right effect_active 3" />
Thank you Dj Fil
geposted Sat 30 Jul 16 @ 6:17 pm
LEDs will never work if a controller is used as a Simple Midi. You will have to create a definition file to get the 100% of the unit's functionality.
https://virtualdj.com/wiki/Controller%20Developers.html
Its in our To-Do list to offer native support for the Launch Control, and will upload test mapping files to our Addons page, probably next week.
If you still want to go that way on your self (and cant wait for a few days), you may download the ver 7 definiton from https://virtualdj.com/addons/16289/Novation_Launch_Control.html
You will have to manually create a (basic/empty) mapping file with the same device name too and probably add a description="" to the definition.
geposted Sat 30 Jul 16 @ 6:41 pm
Does not work on VDJ 8. 2 sorry
geposted Sat 30 Jul 16 @ 6:59 pm
i have a device file you can use send me a email address via PM
nvm i have the same one from djdads post and yes it works
geposted Sat 30 Jul 16 @ 8:27 pm
Hello
geposted Sun 31 Jul 16 @ 1:26 pm
the download above posted by DJDad goes in the -> document/virtualdj/devices/
it is a device file not a mapping
you will need to do the mapping on your own or wait till an official is released
with the file above you can map the led to light up.
geposted Sun 31 Jul 16 @ 2:06 pm
Hello
here is my work... It would be enough to give me one line to program the LED
It should already be able to help...
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="SIMPLE_MIDI_4661_52" version="802" date="2016-07-31">
<map value="0-BUTTON9" action="var '$fxtrans' ? video_transition : deck left effect_active 1 Novar '$Lfilter' ? on : off" />
<map value="0-SLIDER41" action="var '$fxmaster' ? deck master video_fx_slider 1 : deck left effect_slider " />
<map value="0-SLIDER46" action="var '$fxmaster' ? deck master video_fx_slider 1 : deck right effect_slider " />
<map value="0-SLIDER21" action="var '$fxtrans' ? video_transition_slider 2 : var '$Lfilter' ? deck left filter : deck left effect_slider 2" />
<map value="0-SLIDER26" action="var '$fxtrans' ? video_transition_slider 2 : var '$Lfilter' ? deck right filter : deck right effect_slider 2" />
<map value="0-SLIDER22" action="var '$masterfxa' ? deck master video_fx_slider 1 : effect_3slots_layout ? effect_slider 2 2 :deck left effect_slider 2" />
<map value="0-SLIDER42" action="var '$masterfxa' ? deck master video_fx_slider 1 : effect_3slots_layout ? effect_slider 2 1 :deck left effect_slider 2" />
<map value="0-SLIDER43" action="var '$masterfxb' ? deck master effect_slider 1 : effect_3slots_layout ? effect_slider 3 1 :deck left effect_slider 3" />
<map value="0-SLIDER23" action="var '$masterfxa' ? deck master video_fx_slider 1 : effect_3slots_layout ? effect_slider 3 2 :deck left effect_slider 2" />
<map value="0-SLIDER28" action="var '$masterfxa' ? deck right master video_fx_slider 1 :deck right effect_3slots_layout ? effect_slider 3 2 :deck right effect_slider " />
<map value="0-SLIDER27" action="var '$masterfxa' ? deck right master video_fx_slider 1 :deck right effect_3slots_layout ? effect_slider 2 2 :deck right effect_slider " />
<map value="0-SLIDER47" action="var '$masterfxa' ? deck right master video_fx_slider 1 :deck right effect_3slots_layout ? effect_slider 2 1 :deck right effect_slider 2" />
<map value="0-SLIDER48" action="var '$masterfxa' ? deck right master video_fx_slider 1 :deck right effect_3slots_layout ? effect_slider 3 1 :deck right effect_slider 3" />
</mapper>
LED ????
</mapper>
geposted Sun 31 Jul 16 @ 2:27 pm
this sets pad 1 to yellow inactive FX when fx active pad 1 is red all this is only for deck 1
<map value="LED_Pad 1A" action="deck 1 effect_active ? get constant 0.12 : get constant 0.49" />
you must use the devices file or this will not work!
geposted Sun 31 Jul 16 @ 2:48 pm
Thank you for your participation
<map value="0-BUTTON9" action="var '$fxtrans' ? video_transition : deck left effect_active 1" /> ???
<map value="LED_Pad 1A" action="deck 1 effect_active ? get constant 0.12 : get constant 0.49" /> ???
geposted Sun 31 Jul 16 @ 4:50 pm
If you want your own mapping file to work with the definition that you downloaded (and use the LEDs too) you will have to ..
Apparently its the first time you are trying to do this, so if you cant follow my instructions, better wait for a few days.
- use the same device name. So not the Simple Midi
but the name="XXXX" you see in the definition.
e.g. if the definition has
<device name="LAUNCHCONTROL" ....
the mapping files has to be ..
<mapper device="LAUNCHCONTROL" - use the names of the keys that you see in the definition
so not <map value="BUTTON-0"
but the names you see in the definition.
e.g. <map value="BUT1"
geposted Sun 31 Jul 16 @ 5:37 pm
Okay thank you so much
geposted Sun 31 Jul 16 @ 9:21 pm
Novation Launch Control will be natively supported in next build
Here is the Operation Guide to take a look and comment or ask questions.
https://virtualdj.com/manuals/hardware/novation/launchcontrol.html
geposted Sun 07 Aug 16 @ 11:46 pm
The hardware profiles you can build with VDJ is just astounding. Great work.
geposted Sun 07 Aug 16 @ 11:56 pm
geposted Mon 08 Aug 16 @ 7:09 pm
No ETA. Will post here when available
geposted Tue 09 Aug 16 @ 3:02 am
Hello
Okay thank you so much :)
geposted Tue 09 Aug 16 @ 10:20 am
