They done slicked in post fader effects.....Im actually satisfied....Been a long time coming. Thank You.
geposted Mon 01 Aug 16 @ 1:59 am
Woah thanks for posting I didn't even see that.
geposted Mon 01 Aug 16 @ 3:58 am
Yup and its delicious!!
geposted Mon 01 Aug 16 @ 4:22 am
Wait what? Do we have post fader effects now???
geposted Mon 01 Aug 16 @ 4:50 am
I'm so pleased that post fader fx has finally been added.
geposted Mon 01 Aug 16 @ 8:45 am
Just try and tell me you didn't throw on echo/delay and pop the faders up from zero over and over.
geposted Mon 01 Aug 16 @ 12:17 pm
What , what? post fader fader where?
geposted Mon 01 Aug 16 @ 1:14 pm
settings search, fxprocess
geposted Mon 01 Aug 16 @ 1:17 pm
Seriously guys it works as intended and I'm really picky. I hit my echo effect and killed my channel fader and my crossfader separately. It was amazinggggggg. No more loop out to simulate the post fader effect. Plus I'm excited to say how awesome that new build is coming from v8.1 2857 build . I had problems with all the earlier 8.2 builds before updated to the v8.2 3384 build . Plus I can now use my tone play pad effect that Phantom made. I'm excited. Have anyone used the key mod yet and is it easy to use?
geposted Mon 01 Aug 16 @ 1:40 pm
Nice! Thanks for the heads-up Djratedxxx919.
This is exciting! Pardon the bulge.
geposted Mon 01 Aug 16 @ 2:08 pm
Quick demo for those stuck at work
geposted Mon 01 Aug 16 @ 2:13 pm
thanks for pointing it out.
geposted Mon 01 Aug 16 @ 2:33 pm
djrbreezy wrote :
..Plus I can now use my tone play pad effect that Phantom made. I'm excited. Have anyone used the key mod yet and is it easy to use?
FYI, a default Keycue pad page is available in the latest builds of VirtualDJ 8.2
geposted Mon 01 Aug 16 @ 7:55 pm
VDJ 8.2 Build 3343,
Thank You
Thank You
geposted Mon 01 Aug 16 @ 8:05 pm
Guys,
I can not find it :(
geposted Mon 01 Aug 16 @ 9:22 pm
geposted Mon 01 Aug 16 @ 9:56 pm
The keycue page is on the Pad pages. And the post and pre fader are in options/ fxprocesing
GK
GK
geposted Mon 01 Aug 16 @ 10:05 pm
to map it on use
setting "fxProcessing" Post-fader
to map this off use
setting "fxProcessing" Pre-fader
just though that may be handy
to map this off use
geposted Tue 02 Aug 16 @ 12:04 am
Thank you very very much!!!!
geposted Tue 02 Aug 16 @ 5:19 am
Iloveit
geposted Wed 03 Aug 16 @ 3:34 am
