The Copy Paste and Delete works 1/4 of time on VDJ-8.2 OSX 10.9.2 / 2.6Ghz i7/ 8Gb RAM
geposted Tue 02 Aug 16 @ 11:55 pm
check you are actually making the text box the focus, just clicking the window isn't enough [even if the text cursor is in the box]
geposted Wed 03 Aug 16 @ 12:49 am
What are you trying to delete?
geposted Wed 03 Aug 16 @ 9:16 am
If I go in Tag Editor to change some name to copy info to paste it on a next files info it will not copy to paste the box don't come up to do it
geposted Wed 03 Aug 16 @ 1:00 pm
I sure window don't have that problem in VDJ-7 you was not able to cut copy paste (Tag editor / files info) on the mac in VDj-8 you can but don't work all the time.
geposted Wed 03 Aug 16 @ 1:03 pm
for paste try: Ctrl+V
geposted Wed 03 Aug 16 @ 1:24 pm
Doesnt show on my mbp osx 10.10.5 yosemite
I was just retagging some songs and right click doesnt show an options box so i just manually typed info and deleting title from artist field
geposted Wed 03 Aug 16 @ 2:18 pm
There is a similar bug with the action editor not showing a paste option.
Maybe it is the same?
But as above, try using CTRL+V to paste (and CTRL+C to copy). That should still work.
geposted Wed 03 Aug 16 @ 3:24 pm
Don't Have a CTRL on a mac
geposted Wed 03 Aug 16 @ 8:28 pm
Did you try Apple-C and Apple-V ?
https://www.google.fr/webhp?ie=utf-8&oe=utf-8&client=firefox-b&gfe_rd=cr&ei=3uuiV7PiGpDCaPjsofAH#q=ctrl-c+mac
geposted Thu 04 Aug 16 @ 7:18 am
Its Command - C and Command - V
geposted Thu 04 Aug 16 @ 11:33 am
That works maybe that will get fix until I will do the commands Thanks
geposted Thu 04 Aug 16 @ 4:46 pm
