If you are trying to delete a set of files through File Operations - Delete it will not work if one of the selected tracks is exists=0
After removing that track from search db deletion will succeed.
I suggest to automatically remove that track from search db because you are going to delete the tracks anyway.
Or, just skip that file if it is not available.
geposted Wed 03 Aug 16 @ 9:18 am
