On the VMS5 if you push down the center knob for browsing, it
will move from the far left side to the browser section in vdj,
Is there a way to map it to go from left to browser to automix to sidelist?
I tried the mapping I had previously, but no go.
Also looking for a way to load songs from browser to either,
automix,or sidelist.
I thought of the booth knob, but can't get it to work.
I have this mapped via the keyboard, but would like to use the controller.
geposted Thu 04 Aug 16 @ 7:26 pm
This is an update:
Main system has VDJ version 2857.16.
I was not able to change mapping. Every time I would attempt to type anything
it would not allow it.
Typed the mapping in word then I tried to copy and paste, that did not work either.
My backup system has VDJ version 2832.112.
I was able to re map on this fine.
So I copied the mapping to main system and it works.
geposted Sun 07 Aug 16 @ 4:19 pm
You should update to the latest version 8.2. Several copy/paste issue have been fixed already
geposted Sun 07 Aug 16 @ 8:12 pm
Waiting until this weekend to do the update.
Just seemed a bit strange that the older version worked
and not the newer one.
Thanks
Thanks
geposted Mon 08 Aug 16 @ 12:35 pm
hi guys i just got new vms5 & new laptop have downloaded the vdj le & put the key in but mid gig the licence fails can anyone advise if im doing something wrong any help would be appreciated
geposted Sat 20 Aug 16 @ 1:54 pm
what happens when the license fails?
more details please
more details please
geposted Sat 20 Aug 16 @ 2:34 pm
hi it just freezes
geposted Mon 22 Aug 16 @ 11:33 pm
if you go to the https://virtualdj.com/users/edit.html
click on licenses
then enter your LE serial number you will be able to get the latest LE version this may have fixes you need to get things going again.
click on licenses
geposted Mon 22 Aug 16 @ 11:43 pm
hi can someone help vms5 full pro licence but cant seem to set it fader works in opps dir & cue works in opps aswell so fed up just want
to use it fullyr
to use it fullyr
geposted Sat 15 Oct 16 @ 11:00 am
