I'm having this weird problem when I use sliders/knobs. If I'm controlling a knob and I am approaching 100%, the skin acts fine until 100% hits and the knob automatically switches to 0%. However the knob will still be at 100% but it will show it being at 0. This also happens with volume and the crossfader slider. If the volume is at 100%, the volume will be playing at 100% but it shows it at 0. If it is at 90% is will be playing and be showing at 90%. This only happens at 100%. The same applies for the crossfader as if the crossfader is all the way right is shows it being left even though the right side track is playing. But when i am actuallly at 0% or left on the crossfader it shows and acts at 0%.
geposted Sat 06 Aug 16 @ 12:24 am
Is this with some hardware/controller (and which one) or some custom skin (and which one) ?
geposted Sat 06 Aug 16 @ 10:59 am
No custom and no controller. It happens when I use my mouse and click and drag.
geposted Sat 06 Aug 16 @ 5:16 pm
What build number are you using?
geposted Sat 06 Aug 16 @ 5:36 pm
Please download and install the latest version 8.2 from https://virtualdj.com/download/
geposted Sat 06 Aug 16 @ 10:16 pm
Having the same problem
geposted Tue 12 Dec 17 @ 6:52 pm
More info required.
geposted Tue 12 Dec 17 @ 6:57 pm
