Hey, I have a Gemini G4V and the pads react significantly slow in VDJ. Is the latency amount adjustable or not?
geposted Sun 07 Aug 16 @ 4:11 am
Is it just the Pads or do the Jogs and other buttons (like PLAY, CUE etc) provide the same lag ?
If you are using the Gemini ASIO in the Audio setup, what is the chosen latency from the Gemini ASIO control panel ?
geposted Sun 07 Aug 16 @ 3:51 pm
If you change the setting "globalQuantize" from 1 to 0.1. Does it react faster?
geposted Mon 08 Aug 16 @ 9:06 am
