Does anyone know of an alternative for milkdrop? It does not appear we are getting a Mac version :-(
geposted Fri 12 Aug 16 @ 7:24 pm
I have a beta Mac version, however I would need some users who are willing to beta test it and risk things going wrong ;)
geposted Fri 12 Aug 16 @ 9:20 pm
hi im happy to test it thanks
geposted Fri 12 Aug 16 @ 9:43 pm
Sign me up! I would be happy to test :-)
geposted Fri 12 Aug 16 @ 9:47 pm
hi,
try the soundspectrum.com , g force, free edition,
GK
GK
geposted Sat 13 Aug 16 @ 3:22 am
That baddd!
thnx man.
thnx man.
geposted Sat 13 Aug 16 @ 7:01 am
....except their software (inc. Gold and Platinum) is for non-commercial use only. You would need to request a commercial license for pro use.
geposted Sat 13 Aug 16 @ 7:49 am
Only $20.
No problem
Need VDJ Support tho
start a new thread requesting suppoprt
No problem
geposted Sat 13 Aug 16 @ 9:26 am
$20 is for the Gold license - but as I said, that's not for commercial use. Neither is the Platinum at $30.
AFAICS they don't publish a price for the commercial license, so it'll probably be based on the precise intended use, and will certainly be more than $30.
geposted Sat 13 Aug 16 @ 9:48 am
GKAudiO DJ wrote :
hi,
GK
GK
I'll check them out. Thanks!
geposted Sat 13 Aug 16 @ 12:07 pm
I'd be willing to test it out.
geposted Tue 16 Aug 16 @ 12:37 am
Hi,
If you need other mac tester tell me!
geposted Tue 13 Sep 16 @ 4:29 pm
If you know where to look you can use the Visualizer that iTunes uses since VDJ now supports Quartz files ;-)
I'm not at home right now so I can't tell you where to pull it from but if you Google it I'm sure the instructions can found.
geposted Tue 13 Sep 16 @ 5:14 pm
I like where this is going...
I don't see anything online about grabbing a quartz file. Would you be able to elaborate?
geposted Wed 14 Sep 16 @ 1:07 am
put quartz files into your vdj visualisations folder and select them like any other vis
geposted Wed 14 Sep 16 @ 1:10 am
Any idea where to find the quartz file? I did a searich in Windows for qtz and nothing came up. Any suggestions?
geposted Wed 14 Sep 16 @ 1:24 am
My mistake qtz files are mac only, I assumed you were a mac user.
geposted Wed 14 Sep 16 @ 1:33 am
Ah...my gig machine is a mac. So I found the qtz file now and dropped it in the visualization folder and I just get a blue, white or black screen.
Do I need do do anything else in order to get it working as a visualization?
I am also using build 3398 which has quartz supported.
geposted Wed 14 Sep 16 @ 1:45 am
Refreshing this post.
Anyone have luck with a quartz file in the visualization folder? Any info would be greatly appreciated.
geposted Thu 15 Sep 16 @ 11:28 am
Most of the quartz files I've tried have worked - any chance you could share the file?
geposted Thu 15 Sep 16 @ 1:59 pm
