Hi
I'm due to broadcast via my MacBook Air with Virtual DJ 8 tomorrow. Trouble is, I don't have a working power lead. The show I'm doing lasts two hours. Anyone know if my 90% battery capacity is likely to get me through? Or should I continue to panic? I am in a remote place where the possibilities for buying such a lead are pretty much non existent
geposted Sat 13 Aug 16 @ 8:40 am
Battery percentage you never can tell, the more they are used the more the capacity fades, 90 percent on new batt will last longer than 90 on a old one.
UPS over night a lead, beg borrow or steal one,
How remote are you?
How remote are you?
geposted Sat 13 Aug 16 @ 9:01 am
Thanks Loco. You're right. I am in the process of trying to beg borrow or steal. I'm in Cornwall. I did a test this morning for about 25 mins and it only sucked up ten per cent but as you say it's troublingly unpredictable.
geposted Sat 13 Aug 16 @ 9:40 am
