Since build 3324 I'm experiencing that my first attempt to open the software that it does not respond and I have to force quit. It'll open on the second attempt. This happens whether there's peripherals connected or not. I've a Mac Book Pro Mid 2012 with El Capitan 10.11.6. I've downloaded a fresh version and also done a factory reset of my settings, but has not resolved the problem?
geposted Sun 14 Aug 16 @ 5:57 pm
Does the same here using mbp yosemite 10.10.
geposted Sun 14 Aug 16 @ 10:46 pm
Same here with mbp.
geposted Mon 29 Aug 16 @ 6:48 am
Related to controllers or external hard drives connected?
geposted Mon 29 Aug 16 @ 8:17 am
Same here doesn't matter if anything is connected. It doesn't affect anything once it opens it's business as usual.
geposted Tue 30 Aug 16 @ 9:53 pm
same problem here it even gives me a message that vdj is taking long time to open browser
and some times it takes 5 mins to open
am running on win 7 hp i7 8gb ram
geposted Wed 31 Aug 16 @ 6:39 am
I have been experiencing the same thing as well.
MacBook Pro (15-inch, Mid 2012) with El Captain. I have deleted and done a clean installation of Virtual dj but still have the same issue. Am considering going back to one of the earlier versions.
geposted Sun 04 Sep 16 @ 6:44 pm
Having the same issue here. I have to force quit to start on first attempt. Any help on this please?
geposted Sat 01 Oct 16 @ 2:03 pm
cold reboot your pc. everytime you do a mix. it just clears the memory of random crap.
geposted Mon 03 Oct 16 @ 8:33 am
Same issue on one of two MacBooks.
Works fine on: Macbook Pro Early 2015 500 SSID 2.9 GHz i5 8 GB 1867 MHz DDR3 OS X El Capitan Version 10.11.6 VDJ 8.2 b3420
Requires force quit on: MacBook Pro Mid 2012 750 GB 2.9 GHz i7 8 GB 1600 MHz DDR3 OS X Yosemite 10.10.5 VDJ 8.2 b3420
Very frustrating when VDJ 8 does not open. Wheel sits and spins forever. Obvious force quit and it usually opens on 2nd time around. Opens very slowly when it does work. Ran 2 weddings with opening problem and DDJ SR worked fine with no issues thankfully. It never did this before and I cannot nail down what changed as too much changed including Yosemite, VDJ builds etc.
Followed a number of MAC application fixes but damn I need a degree to do some of that stuff.
Anyone else find a fix?
geposted Tue 04 Oct 16 @ 4:29 am
So I did a Cold Boot (Hold down start button until it shuts off) and then tested a full start 8 times or so and VDJ started first time each time.
Interesting.
geposted Tue 04 Oct 16 @ 4:48 am
Same problem here. MBP 15" 2015 OS Sierra. Menu bar only, nothing else start up. Have to force quit.
geposted Fri 17 Feb 17 @ 12:55 pm
