Hello
i was update my virtualdj to the last version 8.2 B3343 i use Macbook Pro 2.3 GHz Intel Core i5 16GB ram its the first time the program crashing my control is Pioneer XDJ-R1 its not freezing its crash and closed without any warning its a big problem bcs i use this program in all my events
please how can find a solution to solve this problem
note the XR! is update it the last version firmware
geposted Tue 16 Aug 16 @ 6:37 pm
We didnt receive any crash report from you. Were you online when this happened ? If not, can you get connected and reproduce the crash ?
Also try to delete the settings.xml file from the /Documents/VirtualDJ folder and try to open VirtualDJ again.
geposted Tue 16 Aug 16 @ 9:07 pm
