I store the majority of my music on my secondary hard drive (F), and I have recently added some songs onto the main Windows hard drive (C). These songs, on the 'C' drive are now showing up in my search results and I don't want them to. I can't figure out how to do it, anyone can shed some light please?
geposted Tue 16 Aug 16 @ 9:21 pm
right-click on the folder(s) of your C Drive that holds the new songs, -->Batch->Remove from search DB
You can also turn off the automation that adds the content of a folder when this is clicked (selected) by turning off the setting autoSearchDB
geposted Tue 16 Aug 16 @ 9:39 pm
Thanks djdad. I have now turned the autosearchDB option off so hopefully any songs that I add to the C drive will no longer be added to the database.
geposted Tue 16 Aug 16 @ 10:01 pm
