I have over 500 tracks that have information in the title I want to remove. It's consistent information, so is there any way to mass edit the tracks or am I stuck doing it one at a time?
geposted Wed 17 Aug 16 @ 1:05 pm
geposted Wed 17 Aug 16 @ 1:10 pm
What is the info please give an example.
geposted Wed 17 Aug 16 @ 1:31 pm
Video files were ripped from DVD with file extensions in the Title tag, so there's extra text in the song title.
"Get The Party Started.mpg.MP4"
Need to get the .mpg.MP4 out of the song title.
geposted Wed 17 Aug 16 @ 1:42 pm
@TDBennet this only renames the file doesn't it? Or am i missing something that will change the song Title info?
geposted Wed 17 Aug 16 @ 2:00 pm
I am a huge fan of Flash Renamer. It's been about 13 years since I've started using it, and it is the quickest way to clean up files for me. Windows, and also works under Wine.
geposted Wed 17 Aug 16 @ 2:34 pm
Give me an example of the file name.
geposted Wed 17 Aug 16 @ 2:37 pm
Sugarland - Already Gone.mpg.MP4.MP4
geposted Wed 17 Aug 16 @ 2:51 pm
Ok so you can't bulk fix the title inside vdj,
using a renaming program means you'll lose you cue points or have to relink [eugh]
best bet would be to ctrl+h in the database xml
search for
and replace with
I'd back up your database first, just incase.
search for
.mpg.MP4"
and replace with
geposted Wed 17 Aug 16 @ 4:33 pm
I'm sorry, you are correct, my suggestion does not meet your needs.
geposted Fri 19 Aug 16 @ 1:12 pm
Mp3tag is what you need. Handles Mp4 files as well. Best of all it's free.
http://www.mp3tag.de/en/
The Mp4 optimize option is also useful to run on Mp4 files to remove any junk in the headers.
To do what you want you need to create an action in Mp3tag to batch edit your files. Very easy to do.
I use it for all my Mp3 and Mp4 files.
Hope that helps.
Hope that helps.
geposted Fri 19 Aug 16 @ 2:00 pm
Hope that helps.
Hope that helps.
+1
geposted Sat 27 Aug 16 @ 10:49 am
