Hi guys,
I'm looking forward to make an automatisation to be able to change playlist at a given specific time ?
Eg the first one starts at 10am to 4pm and the second one starts at 4 pm to 10 pm ?
Have any of you ever done that ?
Would really help me !
geposted Wed 17 Aug 16 @ 8:30 pm
I don't think there is a way to do this, but the playlist does indicate when the next song will start. In the the 'will play at ' column , ao just organize you play list , add all your music until you get to the 6 hours mark, then add your second lot, I know it means meeting two play lists but it will achieve what you want
geposted Thu 18 Aug 16 @ 6:33 am
Maybe you can load the first playlist in the playlist and the second in the sidelist.
Then activate with action "switch_sidelist_playlist". I don't know if vdj reads the time to activate an action.
geposted Thu 18 Aug 16 @ 7:19 am
I think this is possible, I'm just testing if I can query the clock.
*edit*
It appears you can't query the clock, but a repeat start script could do it if you activate it at the right time [10 am]
repeat_start 'plSchedule' 360000 1 & playlist_load 'playlist 1'
you could have it rolling 24/7 changing every X hours, describe more why you want it and I can write something bespoke.
*edit*
geposted Thu 18 Aug 16 @ 2:38 pm
Hi Locodog,
It's basically because the music that will be playing is for a bar when there's no dj, so the first is for diner 10-16, second is for lunch 16-22 and the other one for nighttime 22-3 everyday !
If you could help me it would be really appreciated :)
geposted Thu 18 Aug 16 @ 6:47 pm
If you're planning on using the home free version of VDJ in your bar it against the EULA as it's for non-commercial use.
geposted Thu 18 Aug 16 @ 6:49 pm
We're using the full version !
geposted Thu 18 Aug 16 @ 6:50 pm
Cool, just thought I'd point that out as you are on the forum as a home user.
geposted Thu 18 Aug 16 @ 6:51 pm
repeat_start 'plSchedule1' 28800000 1 & playlist_load 'afternoonplaylist' & repeat_start 'plSchedule2' 21600000 1 & playlist_load 'nightplaylist'
ok put this script on a custom button [change the playlist names to your names], load up your first playlist, and press the button at 10AM.
Now mines a pint of porter.
geposted Thu 18 Aug 16 @ 7:45 pm
The number 28800000 are for the time of the playlists ?
geposted Fri 19 Aug 16 @ 12:53 am
They are milliseconds... but I think Loco's script has a small mistake:
Shouldn't it be
repeat_start 'plSchedule1' 21600000 1 & playlist_load 'afternoonplaylist' & repeat_start 'plSchedule2' 18000000 & playlist_load 'nightplaylist'
Because 16-22 are 6 hours, and 6 hours are: 6*60*60*1000 -> 21600000 milliseconds
22-3 are 5 hours: 5*60*60*1000 -> 18000000 milliseconds
Shouldn't it be
geposted Fri 19 Aug 16 @ 10:10 am
no mistake, daytime [first] playlist is loaded by the user and lasts 8 hours.
I've never ran a repeat script for that long so would like to know if it works out.
EDIT actually yes a mistake [I missed the ms unit]
repeat_start 'plSchedule1' 28800000ms 1 & playlist_load 'afternoonplaylist' & repeat_start 'plSchedule2' 21600000ms 1 & playlist_load 'nightplaylist'
geposted Fri 19 Aug 16 @ 11:10 am
VBscript is the solution
geposted Fri 19 Aug 16 @ 5:32 pm
