So whenever i try to use the sync button to match the bpm to another song on the other deck, the bpm doubles the first songs original bpm. For example the first song is 80 bpm and when i load the next track on the other deck and press the sync button it loads the next track to 160 bpm. Is there a way to change a setting where the bpm will sync to the first tracks bpm not double bpm?
geposted Fri 19 Aug 16 @ 6:02 pm
What is the bpm of the second track?
If the difference is large, it may be that 160bpm is closer to the original bpm than 80bpm.
geposted Fri 19 Aug 16 @ 6:04 pm
I was thinking that could be why it does that, I have one track that was 86.50 and another going to 129, that could explain why it would set the second track to 173 . I had just reinstalled virtual dj so i was trying to get the settings back to how i had them before. So i was just testing to make sure the sync feature was working as i intended. Normally i wouldn't use auto sync for hip hop to edm like i was testing. So this isn't as big of a problem as i thought before. I just felt more comfortable having the track match exactly but double might be better for live reasons.
geposted Fri 19 Aug 16 @ 6:11 pm
