Knows anyone how kann I decrease the Buttons from the Toolbar from Browser.
In my browser these buttons overlap.
And I have seen that in some Skins These Buttons are smaller.
How can I make this?
Here is a Screenshot from my Toolbar.
Greatings Dani
Greatings Dani
geposted Fri 19 Aug 16 @ 9:23 pm
Not sure of the answer but pertinent questions are; what skin do you use, and what's the resolution of your machine
geposted Fri 19 Aug 16 @ 9:37 pm
The resulution of my System 1920 x 1080.
But I think that not the error
geposted Fri 19 Aug 16 @ 9:42 pm
which skin
geposted Fri 19 Aug 16 @ 9:53 pm
I have modified a NS6 Skin...
I have addet more Button in , and have the Browser make Smaler.
You can see it in Screenshot
geposted Fri 19 Aug 16 @ 10:39 pm
This has been a problem since release day of VDJ 8. When the browser is below a certain size, the buttons either disappear or overlap each other.
If you really want to have such a small browser, you could customize it and have the buttons along the top edge instead of the left side - but you would need skinning knowledge, it's not a option in VDJ (although that would be nice to have).
geposted Mon 22 Aug 16 @ 9:10 pm
mmhh ok that also a Idea. But how can I do this , the Toolbar make on another Place from Browser. Or hide any Buttons that I dond Need? For Example I dont Need the Button (go to last Forder).
I guess the problem is with the Resizer by Virtual DJ. If I pull the skin with the mouse less, then the buttons move apart.
A bit has helped it to the Breakline enter something.
But then warp the other elements of skin.
And the Jogs are how Eggs.
If I could the entire skin on 1920x1080 enlarge, then I think it should work.
But this is difficult without disen Skin resizer.
geposted Tue 23 Aug 16 @ 1:57 am
Take a look at the skin TaylaMadeVideo. The browser has been customized and the buttons are along the top edge.
geposted Tue 23 Aug 16 @ 8:27 am
