Topic: Deleted POI's
Hi, i deleted the original POI's from musictrack.
How can i make VDJ to bring them back?
grts
geposted Sun 21 Aug 16 @ 2:38 pm
What do you mean "original" POI's ?
If they were POI's set by yourself then you can't bring them back unless you have kept a backup of your database before erasing them.
With original pois,
i mean the automatically created automix pois.
Mix fade start,
Mix cut start,
And so on...
I deleted them all from some tracks.
How to get them back?
Grtz
Have you tried re-analyzing the track(s)?
OK thanks...reanalysing did it.
grtz
