New guy here, first post.
Trying to create a definition, no issues with that, however the log report shows it's being detected as a general midi device.
--MIDI Device Identifying: \\?\bomebus#bomemidi#02#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\bomemidiin (in:0 out:-1)
--MIDI Device Identified by general midi: \\?\bomebus#bomemidi#02#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\bomemidiin
In monitoring the midi port on the device, VDJ isn't sending the sysex identity request...
Definition file:
<?xml version="1.0" encoding="UTF-8"?>
<!-- file name DN500BD.xml -->
<device name="DN500BD" description="Denon DN-500BD" version="8.xx" author="djMightyMaxx" type="MIDI" decks="1" sysexid="F07E??060200020BF7">
<!-- out commands -->
<sysex value="F0 7F 01 06 02 F7" name="PLAY" />
<!-- this may be wrong -->
<sysexin sysexid value="F0 7F 01 07 02 F7" name = "PLAY"/>
<!-- alternate form can use wild cards as in the device section
<sysexin sysexid="F0 7F 01 07 02 F7" name = "PLAY"/>
<sysexin value="F0 7F 01 07 02 F7" name = "PLAY"/>
</device>
Any help would be much appreciated...
Definition file:
</device>
geposted Wed 24 Aug 16 @ 12:07 am
It's a Blu-Ray player - with no MIDI.
geposted Wed 24 Aug 16 @ 9:11 am
I'm building a midi to serial converter using Bomes midi translator pro...
So vdj it talking to Bomes virtual midi port, which I can monitor on that end, that's how I know it's not sending any sysex discovery on vdj startup....
geposted Wed 24 Aug 16 @ 12:30 pm
Seems that device identification only works by using the midi port name, at least that's the only way I've gotten it to apply the def file.
geposted Tue 30 Aug 16 @ 12:45 pm
