My virtual dj will not open no matter what i do. I double click, i reinstalled the app, the restarted my laptop to no avail. when i click on the app its comes up at the top left of the screen (macbook) but it doesn't appear. Does anyone have the solution to this ?
geposted Sun 28 Aug 16 @ 4:54 pm
bump
geposted Sun 28 Aug 16 @ 11:26 pm
Have you tried to delete the settings.xml file?
Maybe it is opening out of view?
geposted Mon 29 Aug 16 @ 8:48 am
No let me try that
geposted Mon 29 Aug 16 @ 4:25 pm
I just tried that and it still doesn't appear. Im pissed
geposted Mon 29 Aug 16 @ 4:29 pm
Were you using the default skin?
geposted Mon 29 Aug 16 @ 9:39 pm
Yes
geposted Tue 30 Aug 16 @ 12:07 am
Hmm this is weird, I use a Mac and this one has never happened to me.
I'd say trash everything and then download the latest public build and start from there.
geposted Tue 30 Aug 16 @ 12:49 am
I already did I deleted it and reinstalled the software same thing happens.
geposted Tue 30 Aug 16 @ 2:16 am
What are the full specs of your MacBook??
Maybe its a permissions thing, try and repair the permission's then try again.
geposted Tue 30 Aug 16 @ 2:28 am
Minimum requirements for VDJ 8 are OSX 10.7 so if your OS is earlier, that's probably the cause.
EDIT I found some of your earlier posts and you clearly have been running VDJ 8.1 and 8.2 - was this on the same computer?
geposted Tue 30 Aug 16 @ 1:33 pm
Nope im running 10.8.5
geposted Tue 30 Aug 16 @ 6:05 pm
where can i find permissions on macbook ?
geposted Tue 30 Aug 16 @ 6:06 pm
Try using Google perhaps? Or presumably your computer came with a manual.
geposted Tue 30 Aug 16 @ 6:14 pm
https://support.apple.com/en-us/HT201560
geposted Tue 30 Aug 16 @ 7:37 pm
Mine does the same thing! I have to force close and when i reopen it works. It's annoying but i figured one of the updates would fix it.
MacBook Pro (13-inch, Mid 2012)
2.9 GHz Intel Core i7
geposted Tue 30 Aug 16 @ 10:23 pm
