Hi,
Recently upgraded to VDJ infinity and Im really suprised how easy to connect the cdj350 to it.
Now Im trying to figure out how to manage the sound out from Virtual Dj while my Wego controller is connected and so is the cdj350.
Setup
Wego connected to Mac. Using wego soundcard
Cdj350 also connected to Mac. Using cdj soundcard thru mixer.
I cant figure out the sound.
It would look like Im using the wego and the cdj350 as 3rd deck.
Can anyone suggest how this setup will work.
Thanks
Setup
Thanks
geposted Wed 31 Aug 16 @ 9:17 am
You should use the predefined audio setup of WeGO
Then you need to "sacrifice" a knob that you will remap as "deck 3 level" in order to control the volume of deck 3.
Your sound will still come out from WeGO.
You can also remap a button on your CDJ as "pfl" in order to be able to prelisten the deck on your headphones.
geposted Wed 31 Aug 16 @ 12:55 pm
Thank you PhantomDeejay.
So if Im using a controller with a four deck options. The cdj although the sound is course thru a mixer. Can only output sound thru the software.
Correct?
But its different if i hook up just 4 cdjs to my laptop cdj audio out thru mixer.
are this setups possible?
Correct?
geposted Thu 01 Sep 16 @ 3:47 am
