Hi, it's my first topic about crashing VDJ.
I have a controller pioneer ddj wego - it's a gift from previous owner ( without serial nomber fo VDJ LE - lost, damaged - no matter).
I bought the version virtual dj which supports my controller (ddj wego) - $99 for it.
During i play different traks, virtual dj periodically crashed - the system is not responding any manipulation of the controller - music is still playng but a cannot control the process of mixing.
And I paid 99$ for that - for crashing VDJ? When i'll recording my mixes - if the system will crashed againg, what am I supposed to do?
Who will give me back my money for not working product? I suppose - nobody. couse VDJ is not refunding product.
So I hope to the technical support help.
geposted Thu 01 Sep 16 @ 7:14 pm
what version VDJ you running ?
check this link if your running 3386 and update to 3390
https://virtualdj.com/forums/212202/VirtualDJ_8_2_Technical_Support/Virtual_DJ_8_2_B33866_Crashing_when_loading_tracks.html
https://virtualdj.com/download/build.html
geposted Fri 02 Sep 16 @ 5:14 am
Thanks. I'll hope there no crashing on this evening during my set
geposted Fri 02 Sep 16 @ 2:46 pm
You should be using the last stable version for gigs, not the beta.
geposted Fri 02 Sep 16 @ 6:09 pm
What is the latest stable version? Because the latest beta version has some serious issues.
geposted Tue 18 Oct 16 @ 6:17 pm
Old School
Bookmark it
Bookmark it
geposted Tue 18 Oct 16 @ 10:07 pm
