Can anybody help when I search for songs in my library sometimes it comes up with short samples of the song as well as mine ,how do I Disable this from happening
Thanks
Jez
Thanks
Jez
geposted Thu 01 Sep 16 @ 8:19 pm
Turn off the internet searching (Netsearch & Content Unlimited).
geposted Thu 01 Sep 16 @ 9:15 pm
You will need to exclude (remove) those short tracks from the Search Database
Click to select the folder(s) those samples are located and right-click ->Batch->Remove from Search DB
Additionally , you will need to turn off the setting autoSearchDB so that VirtualDJ stops adding the content of the folder automatically to the Search Database when you browse folders.
geposted Thu 01 Sep 16 @ 11:49 pm
