Has anyone use iRig Pads with Virtual DJ 8? I'm trying to find a way to map the pads to VDJ8 so I can use it as a sampler and hot cue.
geposted Fri 02 Sep 16 @ 11:04 pm
Not yet natively supported so you'll have to write your own definition file and mapping.
Also your LE license won't cover usage over 10 minutes so atm only a pro licence/subscription will do.
geposted Fri 02 Sep 16 @ 11:44 pm
