Topic: Old build 8.2 - Page: 1
Where can I download old build from 8.2, I have issue with the build v8.2 b3390 ,on this last early build my set up for timecode is very Weird when I active the timecode mode in my rmx2 the sound of the song slow down ,but when I remove timecode mode goes faster,so please show me where can I get old build Thanks!!!!!!!
geposted Sat 03 Sep 16 @ 4:53 pm
Just get it from the download page or your account. The public build is still 3343.
Thanks for respond quick I will try ...
For some reason wont install the 3390 still ,I will restart the computer and I let you know
Still 3390 ,what step I humo because I download 3343 and I install regular but when I open vdj still 3390 any help PLEASE,,
Any clue how to solve this issue!!!!!
I want remove the last build 3390 wont remove ,what I need to do!!!
Before uninstalling try clearing your cache folder in Documents -> VirtualDJ -> Cache
remove only the files not the folder present in it
I did but nothing change!!!
Hi locodog is Mac!!
locodog wrote :
https://virtualdj.com/download/virtualdj8/pc/3343/zip
This is what I did
Download from vdj 3343 I install and 3390 build stay there .
Wont work any other ways!!!!! Please I have event tonight......
No clue????
go to options - turn off Early Access
go to account page - my licenses - re-install 8.2 b3343
I have the same problem...I will download the old b3343 and it works. But when you close out VDJ8 and reopen it will revert back to b3390. I want to get rid of the early access of anything after b3343. How do we do this. Ever since I have updated with the next 3 builds of early access everything I was doing has been messing up. Not working properly, especially the Karaoke graphics not in sync with the audio. Even the updates did not fix it. Please help...causing a problem at my gigs.
options - search for updates no
Found a solution...I removed VDJ8 from my mac and redownloaded b3343 from my account page (licenses). I had all kinds of problems when downloading the early access after the b3343. I am running great now with the build 3343. You have to completely remove from computer then reinstall. It works...try it. I did a back up of my settings before so if anything got lost. All remained the same with absolutely no problems. Hope this helps.
iLlL try!!!
Did it work for you?
95%
