You don't have access yet to any Reserved forums.
Participate in the general forums to raise your level, and you will unlock new forums.
geposted Sun 04 Sep 16 @ 4:01 am
Some forums are reserved for members who have privileges. That's exactly what it is.
What were you trying to access?
geposted Sun 04 Sep 16 @ 9:37 am
I have been able to go in the forum for years I have been involved in several conversations??? STOP I think I see what happened!!!! To whomever was able to make this happen THANK YOU! I have tried to get this changed for years. I was told it was not possible.
geposted Sun 04 Sep 16 @ 1:37 pm
Will it eventually show up under my logo
geposted Sun 04 Sep 16 @ 1:40 pm
In what forum?
Yes? What happened?
Make what happen?
Tried to get what changed?
Your posts are almost indecipherable. It's as if you're merely having an internal dialogue with yourself, rather than communicating with others.
Please try and post enough information so that people can understand what you're asking/saying.
geposted Sun 04 Sep 16 @ 2:12 pm
It's the Supernatural Forum. One must have the ability to post on a forum and convince other posters he is actually talking to himself.
geposted Sun 04 Sep 16 @ 3:07 pm
I've being doing this for years... rofl
geposted Sun 04 Sep 16 @ 6:41 pm
I asked to have my login name set to my DJ name about 6 months ago and I was told it can not be changed but all of a sudden it is changed
geposted Sun 04 Sep 16 @ 8:26 pm
This only changed on my login did not change on the forum So I'm guessing it looks like I've never been on
geposted Sun 04 Sep 16 @ 8:36 pm
geposted Mon 05 Sep 16 @ 12:18 am
The forums you are unable to reach are for users who have access to experienced forum a minimum requirement of four stars is needed, another forum is reserved for users with a minimum requirement of five stars and above in their profiles, and finally their is a non English forum that also requires four stars to access it.
So unless you now have less stars to your profile then when you woke up the other day, nothing has changed, if you have less than you did you need too contact support for clarification on your status.
geposted Mon 05 Sep 16 @ 12:31 am
This used to be for PRO Infinity users only and I had access to that. did this change?
geposted Mon 05 Sep 16 @ 6:30 am
As far as I know, the star limitations have always required those user ratings, I would either wait for a mod or a member of the team to comment or raise a ticket with support.
It may be that access changed for users when V8 was released but I couldn't comment on that.
geposted Mon 05 Sep 16 @ 9:17 am
As far as I can tell there was no specific forum for Pro Infinitity users only.
Some threads CAN be leveled to be visible to pro users only.
But that only happens not to hide something from lower user levels, instead it is used to protect user data. I.E. if someone posted some personal details like a phone or email adress or any other information that should not be publicly available.
geposted Mon 05 Sep 16 @ 12:32 pm
You previously had ContentUnlimited so had access to the Premium Members forum, however your subscriptions ended a couple of days ago.
geposted Mon 05 Sep 16 @ 1:30 pm
Thank You this makes much more sense
geposted Mon 05 Sep 16 @ 3:25 pm
Ok i fixed it new card came in. Reorder and the Forum came back
geposted Tue 06 Sep 16 @ 1:52 am
How you can get more star to see the reserved forum?
geposted Wed 04 Jan 17 @ 5:43 am
By not hijacking dead threads for one. Generally just by being useful to the community,
https://virtualdj.com/wiki/How%20do%20I%20become%20an%20Experienced%20or%20VIP%20Member.html
Skins, plugins, advice, ideas, good fault reporting,
geposted Wed 04 Jan 17 @ 6:47 am
Cross my palms with silver would be a good start... I'll then send you a map.
geposted Wed 04 Jan 17 @ 1:11 pm
