Hi
Whenever I open Virtual DJ, I get following message.
geposted Mon 05 Sep 16 @ 3:01 am
What is the actual question here
geposted Mon 05 Sep 16 @ 7:11 am
The question is: Do you want to stay with what you have = No or do you want to use the new update = Yes.
geposted Mon 05 Sep 16 @ 3:17 pm
so are you saying if you say yes is it not updating . the bottom left side of the setup page will tell you what version you are on
geposted Mon 05 Sep 16 @ 3:47 pm
Yes I click yes, but it doesn't update. V8.2 b3378
geposted Mon 05 Sep 16 @ 4:05 pm
What does it do? What happens when you press 'yes'?
One thing you should check is that you don't have multiple VDJ exe files running in the background. This still happens quite often (I guess it doesn't shut down fully) and it will prevent the update from installing.
geposted Mon 05 Sep 16 @ 6:23 pm
When I press yes, Virtual DJ closes. I type my windows administrator password and Virtual DJ opens. I get the message your Virtual DJ has just been updated! Do you want to use the new version now? Yes or no.
geposted Tue 06 Sep 16 @ 3:55 am
Virtual DJ has just updated to V8.2 b3398.
Thanks.
Thanks.
geposted Wed 07 Sep 16 @ 12:23 am
it's already updated you plonker that's asking if you want to use the new updated one
geposted Wed 07 Sep 16 @ 3:02 pm
No, that's not correct (you plonker). It only actually updates the main software once you confirm (click 'yes'). That's why VDJ shuts down and restarts.
geposted Wed 07 Sep 16 @ 4:59 pm
