Hello,
I have my Keyboard numbers 1-0 mapped to sample banks and FX. The problem is that when the cursor focus is on the search box I cannot use the key commands to trigger samples and FX. The keys will only enter text in the box when in search mode. I have to click on a non search box area of the VDJ interface to remove focus from the search box and get my key commands to function again. Right now I have the Tab key mapped to put the focus in the search box. Is there an opposite command to remove focus from the search box so that mapped keys function properly?
UPDATE: I found what I was looking for! The option is called "clear_search" and once mapped it clears the search string and removes focus from the search box!
geposted Mon 05 Sep 16 @ 7:11 pm
just hit ESC key
geposted Tue 06 Sep 16 @ 1:26 am
