can anyone help with mapping I know i can not change color of pads but is there a way to
1) list them from left to right instead of up and down?
2) is there a way to make the light on the sample blink or only come on when in use?
geposted Wed 07 Sep 16 @ 2:23 am
1] Mine go left to right
and
2] Mine blink I believe when a sample is playing.
Ill check mine in a bit and report back but Im sure when Im pressing hotcues lets say I go left to right ,
pad1 pad2 pad3 pad4
pad5 pad6 pad7 pad8
Isnt that what your do??
and
pad1 pad2 pad3 pad4
pad5 pad6 pad7 pad8
geposted Wed 07 Sep 16 @ 2:30 am
the hot cues list from left to right but the sampler list
S1 S3 S5 S7
S2 S4 S6 S8
and they all stay lit so you can't see witch one is on without going into the software
Sampler Only
S1 S3 S5 S7
S2 S4 S6 S8
Sampler Only
geposted Wed 07 Sep 16 @ 2:47 am
Just checked my samples are they are left to right, same as my hot cues. They don't blink, mine just run a brighter blue when on while the ones not playing are dim.
Do you have your padslayout set to "automatic" in the sampler options??
geposted Wed 07 Sep 16 @ 2:57 am
yes
geposted Wed 07 Sep 16 @ 3:01 am
Hmm that's strange, maybe Bob or Phantom can chime in.
Are you using a custom mapping??
geposted Wed 07 Sep 16 @ 3:07 am
no right out the box
geposted Wed 07 Sep 16 @ 3:08 am
ok i got it to go in the right order i do not know what i did but it is good now the light is still always on no dimming or flash just on
geposted Wed 07 Sep 16 @ 3:19 am
so anyone know what to do here this sucks there has to be a way to map this to flash or only come on if it is playing
geposted Wed 07 Sep 16 @ 4:21 am
On the right side of the unit there's a "dim" switch. Try switcing it.
geposted Wed 07 Sep 16 @ 7:03 am
that helped it now gets brighter when activated is there a way to make it flash maybe even to the BPM when actived or just flash
geposted Wed 07 Sep 16 @ 1:39 pm
You will need to remap all the "sampler" related keys of your SP1, or modify your sampler PAD page on the software.
If you can wait, I can do the second job for you.
geposted Thu 08 Sep 16 @ 10:17 am
