According with VDJPedia,now Numark Mixtrack Platinum is supported by VDJ but i cant not set up, any help, thak you.
geposted Sat 10 Sep 16 @ 4:36 am
Exactly which aspect of the set up is not working?
Does VDJ recognise the Mixtrack (does a message appear, asking if you want to use it)?
Is the Mixtrack listed in config/controllers?
What are your audio config settings?
geposted Sat 10 Sep 16 @ 8:05 am
