I use the version b3398, and after 10 minutes of system crash.. anybody help??
geposted Sun 11 Sep 16 @ 12:55 am
Can you list all the plugins you used when the crash occured. There is one plugin that crashes when you exit it (write of the .ini file). A video transition maybe?
geposted Sun 11 Sep 16 @ 12:45 pm
Hi VJPython
I have exactly the same issue. Did you ever solve it. My PC just locks up, Control Alt Delete won't work. Normally locks after approx 10mins mid way through a video.
yet strangely it worked fine other day for several hours. Turned it back on next day and crashes every 10 mins again. driving me nuts.
geposted Sun 18 Sep 16 @ 8:41 am
The most recent software that I got only today (18-9-2016) is v8.2 b3409. I had issues with my denon controller but they seem to be resolved with this update.
Problems started with versions higher than v8.2 b3343 Try to get a newer version maybe?
geposted Sun 18 Sep 16 @ 12:33 pm
Thank you stevoqx!
geposted Mon 19 Sep 16 @ 2:59 pm
