Hi,
Sometimes I listen to a hot cue in deck 2, then load it to deck 1 and there is no color on the hot cue pads for deck 1 as there is color on deck 2.
This has been happening for sometime. Do you have any ideas?
geposted Tue 13 Sep 16 @ 2:49 am
Does anyone have an idea with this?
geposted Mon 19 Sep 16 @ 12:52 am
Can you provide some more info?
From your description I cannot understand the issue.
1) Does this happen all the time or randomly ?
2) What do you mean there's no color ? There are hotcues stored but the leds of the controller do not light up ?
3) Are you using the native (factory default) mapper or a custom one ?
Please try to provide as much info as possible and as more clear as you can.
Thank you!
Thank you!
geposted Mon 19 Sep 16 @ 7:51 am
