I have 4 buttons set up for controlling level %. One is deck 1 level 100%, another is deck 1 level 100% while_pressed, and the other two are the same as above but for 0%.
Instead of the level % jumping abruptly, is it possible to fade from 0% to 100% very quickly, to give the effect of using a linefader?
geposted Wed 14 Sep 16 @ 4:28 pm
repeat_start_instant 'rsiFadeD' 33ms & level 0 ? repeat_stop 'rsiFadeD' : level -0.04
will drop from 100% to 0 in 0.825 seconds
geposted Wed 14 Sep 16 @ 4:44 pm
Thanks that works as a fader. But fitting it into my existing code is is more complicated than I thought. I also have a cancel script attached to the buttons.
Button 1 acts as a 100% to 0% level while_pressed:
down ? deck 1 volume 0% : var_equal 'cancel 1_0%' 1 ? nothing : deck 1 volume 100%
Button 2 acts just as a 100% to 0% level, but also cancels Button 1:
set 'cancel 1_0%' 1 while_pressed & deck 1 level 0%
Is it possible to fit a fader script into these?
geposted Wed 14 Sep 16 @ 5:45 pm
