Topic: Milkdrop and VDJ 8.2 question
I recently moved to VDJ 8.2 and so far so good, except I can seem to find the controls for Milk Drop and TellyVisuals. in 8.1 WHen it was activated, the controls for the length, fade etc was in the bottom right corner of the VDJ screen. I've looked in options and didn't see how to make changes to the display. Thanks
geposted Fri 16 Sep 16 @ 3:08 pm
use the drop down menu and click the little cog icon for settings and it should bring up the menu
I failed to mention that I tried that and when I select the drop down and select the settings wheel on the right, nothing happens. But since this posting I reinstalled Milkdrop and it's working fine again.
But when I reinstalled it appears that it's affected my mapping for my DDJ-SX2. When I upgraded to VDJ 8.2 my pads went from being all the same color to multicolors for each cue point set on the pads and after the milkdrop reinstall they reverted back to all the same color. Nothing else so far seems to be affected.
