I'm using 2 denon sc3900's and a mc6000mk2 and the latest vdj build with Windows 10. When I have a track playing on one deck and then drop in a second track on the other deck the second deck will often times drag behind the first and play in super slow motion. It takes reloading the track to get it to stay in sync. Then if I nudge the wheel to make minor adjustments it will begin to drag behind again. Any suggestions I never had this issue until the last couple of builds.
geposted Wed 21 Sep 16 @ 1:42 am
Does it happen on both decks or only on one ?
It sounds like if one of your pitch bend buttons stucks and stays pressed....
geposted Wed 21 Sep 16 @ 2:15 pm
ThanKS for the post. Yes it happens on both decks. It should be noted that it mostly happens when I nudge either deck to make minor adjustments. It started occurring about 3 months ago. So I was wondering if it is a build issue. A member posted something similar a month or so ago and said it was fixed with build 3398. I have already downloaded 3409 and tried to download 3398 but when I did it still showed me using 3409. So I'm kinda dead in the water
geposted Wed 21 Sep 16 @ 7:05 pm
