hey, trying hookup mixtrack 3 to laptop via dj io 2 but drop down options are totally diff to any forum or instruction manual. help!!
geposted Thu 22 Sep 16 @ 3:43 pm
In VirtualDJ Settings-->AUDIO tab you should see a special button for the sound card. If you click on that, it should automatically create the pre-defined audio setup for you and then just hit APPLY. Both speakers and Headphones need to be connected to the sound card
geposted Thu 22 Sep 16 @ 3:58 pm
I am trying to connect my M-Audio Fast Track Pro. What is the correct configuration to get each deck out to the distinct output. Both decks keep going to the same main output.
geposted Fri 23 Sep 16 @ 6:44 pm
