My computer keep crashing, blue screen and the song sometime drag especially when i switch screens. my computer specs: Processor: intel i7-6700 HQ CPU 2.60 GHz, Memory: 8.00 GB (7.86) usable, system type: 64 bit operating system.
geposted Thu 22 Sep 16 @ 9:01 pm
No, I think there is only the Windows and Mac versions you can download on this page
The VDJ lead developer (Adion) have written about windows crashes (blue screens) in the past, where he explained that those are normally due to issues with a driver (often the one for the graphics card/video/screen) or bad hardware. The idea is that "ordinary" software that sits on top of the drivers, like VDJ does, does not have the power to create such a crash - only lower level drivers and other low level issues can do this
An example of this was a problem with the combination of a Win10 update and a nVida video driver a while back, as explained in this thread:
http://it.virtualdj.com/forums/207509/General_Discussion/WARNING__Windows_10_nVidia_Issue.html?page=1
geposted Thu 22 Sep 16 @ 9:44 pm
the difference in this case, is the computer is a brand new computer, being happening since i install the VDJ. I run NS7III with it, not sure if thats the problem. As there is no real mapping for the NS7III
geposted Fri 23 Sep 16 @ 12:48 am
NS7III has native support -> https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
update vdj to get that support
geposted Fri 23 Sep 16 @ 12:58 am
I have it set, so as soon as the new updates comes out, it ask me to update. so updating isn't the issue.
geposted Fri 23 Sep 16 @ 1:23 am
Any information from the blue screen would help diagnose the cause of your issues :)
geposted Fri 23 Sep 16 @ 3:14 am
Ill take a screenshot of when it happens again. but its a reboot screen.
geposted Fri 23 Sep 16 @ 5:29 pm
This program will give a report on the minidump.dmp files. So when you reboot, you can run it and get more information about the cause of the issue.
It will automatically read the dmp files created after the BSOD.
This is just a zip file that includes help and BlueScreenView.exe. Unzip into some folder and run BlueScreenView.exe. No installer.
http://www.nirsoft.net/utils/bluescreenview.zip
This is a full installer for it:
http://www.nirsoft.net/utils/bluescreenview_setup.exe
This is the main website.
http://www.nirsoft.net/utils/blue_screen_view.html
geposted Sat 24 Sep 16 @ 3:41 am
install google chrome 32 bit. thern 64bit. and see how much more ram 64 uses. most apps are still 64 bit. ever notive traktor is 650megabytes, serato 250 and you have to install quicktime? and vdj is what 40mb? thats tight coding. and thats a good thing.
geposted Sat 24 Sep 16 @ 9:44 am
I also run the NS7iii and had a BSOD. I used Blue Screen Viewer (thanks Don) to view the event. I think it is the Numark NS7iii driver:
Dump File - 091016-5921-01.dmp 9/10/2016 4:28:46 PM DRIVER_IRQL_NOT_LESS_OR_EQUAL 0x000000d1 00000000`00000184 00000000`00000002 00000000`00000000 fffff804`7080b17b NumarkNS7III.sys NumarkNS7III.sys+1b17b x64 ntoskrnl.exe+14a0d0 C:\WINDOWS\Minidump\091016-5921-01.dmp 8 15 14393 558,612 9/10/2016 4:29:18 PM
#1 - ntoskrnl.exe ntoskrnl.exe+e1a5 fffff803`f7e0e000 fffff803`f862e000 0x00820000 0x57b7e3c6 8/20/2016 12:59:50 AM
#2 - NumarkNS7III.sys NumarkNS7III.sys+1b17b fffff804`707f0000 fffff804`70878000 0x00088000 0x554cba67 5/8/2015 9:30:15 AM
geposted Sat 24 Sep 16 @ 4:48 pm
The new anniversary windows update will make some drivers crash. Personally, no problems from my end with asio drivers. I suggest you roll back windows update or reinstall drivers with windows 7 capability.
geposted Sun 25 Sep 16 @ 5:28 pm
I'm all Mac, so my executables are all 64-bit.
I see why Atomix doesn't do a 64-bit version on PC's, since there's still a substantial number of PC's running 32-bit and keeping up 2 versions for PC would be additional investment. (Also, I can't see VDJ ever needing to access more than 4GB of RAM, so it would be pointless.)
There's some thought of 64-bit apps being more stable than 32, however that is untrue and unfounded.
geposted Tue 27 Sep 16 @ 1:39 pm
thanks, i will be sure to check this out.
geposted Wed 05 Oct 16 @ 1:41 pm
