Hello
small question of curiosity, is ' it is possible to get your hands on the / files of the default skin for virtual dj 8.2? (on the previous version there was the zip file of the database virtual dj skin in the skin, since version 8.2 folder this file no longer exists, is you it integrated directly into the virtual dj ".exe" file? or this cache you it elsewhere under another name or other ? )
Thanks in advance :)
( Sorry if my English is not top ) :)
geposted Sun 25 Sep 16 @ 12:55 pm
totof wrote :
Hello
Yes, when you choose the default skin, there is a link in the bottom right of the screen where you can download the files
geposted Sun 25 Sep 16 @ 12:57 pm
klausmogensen , thank you for your help ;)
geposted Sun 25 Sep 16 @ 3:22 pm
