hello, I have a problem since the last update or because of my new Denon.
I no longer sync. only the first deck is a reference and the other deck snaps to it.
geposted Tue 04 Oct 16 @ 4:10 pm
I found, the autosync blocking on deck 1
geposted Tue 04 Oct 16 @ 5:22 pm
Not sure what you mean by "autosync" but most likely its the MASTER deck selection that makes decks to sync each other.
By default VirtualDJ auto-selects the MASTER Deck (the deck that all other Decks will sync to) based mostly on which deck is playing out live. This covers most of the cases.
In case you need to force a different deck as MASTER, you can then use the MASTER text/buttons on the skin or use SHIFT+SYNC on the controller on the deck that you want to select it as MASTER.
From that moment (you manually select a Deck as MASTER), VirtualDJ stops auto-selecting the MASTER Deck. In case you need to go back to the Auto-selection of the MASTER Deck, you need to click on the currently selected as MASTER deck on either the MASTER text/button on the skin or using SHIFT+SYNC on your controller.
geposted Tue 04 Oct 16 @ 5:46 pm
it's silly in the old version of the virtual "autosync" lined the speed of sound entering the sound output
geposted Wed 05 Oct 16 @ 12:23 am
the problem only with denon, not with pc only
geposted Wed 05 Oct 16 @ 12:25 am
