Forum: Report a bug
Topic: B26 - Automix stops
I had a strange problem in automix mode: for an unknwon reason, after x songs, the automix stops. That means, the automix button is still active, but the next song is not played. If I disable then enable the automix again, then it starts again. I had this problem twice this afternoon.
geposted Sat 07 Jun 03 @ 7:30 pm
A 3rd time a few minutes ago. This time it was more strange. The left deck was paying. At the end of the song, the left deck didn't start and the crossfader keeped the left position. Then instead of disabling and enabling the automix again, I tried to play manually the right song. It worked, but I wad unable to move the crossfader to the right position. I stayed locked to the left position. After disabling/enabling the automix, it worked again.
just in case : check the filenames on which the automix has stopped and see if it is always the same file or something else (does the bpm has a * or a !)
(does the filename own some characters like é è à ï ....)
It might help stephane to see where the bug comes from.
