Hello, I have been tryin to find out what these cues are called so that I may create a keyboard shortcut with no luck... The cues I am referring to are right at the top center of the screen and each deck has four of them. When I hover over them I get no id on them... When I hover over the circles to either side of them it says goto -4... I would like the name to these and if possible to create a keyboard shortcut for them... Tank you
geposted Fri 07 Oct 16 @ 10:15 am
They aren't cues that's the beat counter
really all you can do with them is go forward or backwards 1 beat, with the mouse it's a bit more dynamic
so the scripts you want on 2 keys are
goto +1
goto -1
The is something similar with the beat jump pad page too.
goto +1
goto -1
geposted Fri 07 Oct 16 @ 10:37 am
Okay Thanks for the correct term... Is it possible to create a keyboard shortcut for them?
geposted Fri 07 Oct 16 @ 10:39 am
I use the mouse to add chops in the music and find it a little inconstant to use... A keyboard shortcut for these would be a big help
geposted Fri 07 Oct 16 @ 10:44 am
Go to the keyboard mapping and assign buttons to the commands above.
geposted Fri 07 Oct 16 @ 10:51 am
Right a quick text tutorial
Open config
Open the controllers section
You'll see your keyboard mapping
click in the text box below where it says 'key'
press the key you want to use
vdj will bring up the mapping on that key already in the action text box [it could be blank]
the action text box is where you type your mapping
do all the keys you want to map
once you've done close the config window
vdj will ask "mapping has changed do you want to save"
click yes
rock on
Open config
click yes
rock on
geposted Fri 07 Oct 16 @ 10:56 am
Thanks! Big help, just what I was looking for!
geposted Fri 07 Oct 16 @ 11:07 am
