Topic: MC6000 Mk1 cue/crossfader issue
Hopefully I can explain this clearly so I can help a fellow DJ.
MC-6000 Mk1 set up for two channel hardware mixing with v7.4.7 as per the wiki.
First half hour everything is fine, then for no reason the non playing deck loses all volume. Nothing in the headphones and the VU is showing nothing.
Move the crossfader to this deck and the VU springs to life and you have audio.
Now the problem has moved to the other deck. Same symptoms - no sound, no VU.
Only thing I didn't check when I was there was the switches on the back of the mixer so have asked for those now.
I've encountered many issues in my time with VDJ, but this one has me stumped.
Help please...
geposted Fri 07 Oct 16 @ 10:38 pm
what is your setting?
geposted Tue 27 Dec 16 @ 11:50 pm
