Hi, I use a windows 10 laptop normally, with virtual but just testing out brand new Mac that's just been bought, with Virtual DJ, and I cannot seem to scan for music on it. The drive would be NTFS most likely as that's what I used on my windows laptop. I've read on the forum and other sites but each give differing answers. Anyone who has a Mac running with virtual, please could you advise? Would be much appreciated. Just trying to set it up and not that used to Macs to be honest. Just need to build new database again so when typing in virtual it'll bring up the song searched. Thanks again.
geposted Sat 15 Oct 16 @ 10:33 am
You need something like this to properly use NTFS drives on mac:
https://www.paragon-software.com/home/ntfs-mac/index.html
geposted Sat 15 Oct 16 @ 11:10 am
Adion - thanks for the advice. Much appreciated.
geposted Sat 15 Oct 16 @ 12:21 pm
I use a drive on both Mac and Windows and I use the exFAT format.. works perfect
geposted Sun 16 Oct 16 @ 8:27 am
Thanks, I may try that also. I'll try the Paragon software see what happens with that. If that fails, I'll try the exFAT system.
Much appreciated for your help!
geposted Sun 16 Oct 16 @ 10:14 pm
